Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
Configure the PIM virtual neighbor:
Switch:1(config)#ip pim virtual-neighbor 192.0.2.0 198.51.100.0
Variable definitions
Use the definitions in the following table to use the ip pim virtual-neighbor command.
Variable |
Value |
{A.B.C.D} {A.B.C.D} |
The first IP address indicates the IP address of the selected interface. The second IP address indicates the IP address of the neighbor. |
